Driver side brake light ground issue
4Runner@504
Good morning all I Jane a 2003 Toyota 4Runner limited edition and my driver side rear taillight has a grounding issue every time I apply my brakes the interior lights come on also my droner side blinker comes come bit don’t blink but has a very dim light when the brakes are applied this issue is only when my brakes are applied I checked my ground from the battery to driver side fender and that is grounded can someone help me thanks
How did you check it? multimeter?
Have you checked the ground from the battery to the body in the engine compartment with a multimeter?
Has the vehicle ever been in a serious accident?
Do you have serious body rust?
What you're describing sounds like a poor connection between the battery (-) and the vehicle body. Look for a ground strap in the engine compartment and check it for corrosion or loose connection. Use a multimeter set to 20K or 200K ohms and see if the meter will read close to zero (no resistance)
Thanks for the info there is no rust no accidents I checked the ground from the negative battery to the fender well that’s all
Replying to your PM here as well
The body/chassis of your car is the ground/negative for all/most of your electrical connections. Wires for the power/positive run through the wiring harness for all the different components; radio, lights, motors, etc. There is a grounding strap that goes from your battery's negative post to the car's chassis. If the wire has a bad or corroded connection at the chassis connection or at the battery negative post you will have all kinds of strange things happening.
DC electricity (all cars have DC electricity in the wiring) flows from high potential to low potential. If you have a poor ground connection then electricity looks for another low potential. This could be the positive wire on another device in the circuit. That is probably why your interior lights come on (dimly) when you step on the brake.
You don't say how you are testing the fender for a good ground connection. If you don't have a multimeter then try running a separate wire from the NEGATIVE battery post to the fender. Find a bolt on the fender (maybe in the wheel well area) and connect to that, then try your brakes, turn signal etc. If they work properly then you have a poor ground to the chassis.
2001ATL
