Drivers side speaker not working
Foo-Fighter69
Hello every one I just recently installed new speakers to the front of the car drivers and passengers side. They worked fine for 2 weeks then the drivers side stopped working. I took the speaker off to see if it was a loose connection. I switch speakers the drivers side worked fine on the other side so its not the speakers. It might be the wiring going to the radio. What should I do to get this fixed. Whats the best way to go about this?
Sounds like the wire coming out of the head unit, is it still factory or has it been replaced? If it's been replaced, I would check the wires on the harness coming out of the head unit
I have the same problem! How did you fix it?
I am having the same problem! I just got new speakers.. they were working fine and then recently both front and back driver-side speakers are much quieter than passenger side.
Were you able to solve your problem? If so, what did you do? I have a stock headunit.
Same problem, but with stock radio and speakers. I have the factory navigation, if that matters. Problem is intermittent, and can be resolved by turning on the system and off again. Seems to be affected by bumps in the road.
