Driveshaft Flange Bolt Patter - '03 V8 4wd T4r
aemravan
Senior Member
Does anybody know for certain what the flange bolt patter is on an 03 v8 4runner..? In particular the rear drive shaft, both at the t-case and at the 3rd member (can't imagine these are different).
From what I saw I could have sworn it was a 65x65mm square bolt pattern with 8mm hardware, but that does not appear to be correct according to the DS spacer I ended up having to drill out slightly.. needing to order another spacer for a different application and do not trust my measuring or info I am finding...
thanks in advance!
I'll see if I can crawl under mine in a bit and get a measurement for you. I have a 2003 SR5 V8 and this is the driveshaft I purchased for mine, it bolted right up:
More Information for DORMAN 936777
I don't see a bolt pattern in the spec so that doesn't help you, but like I said maybe I can measure mine here in a few for you.
EDIT: this is the front driveshaft
no need to crawl under and measure, I appreciate it though! I can pull a measurement off of mine too but I could have sworn I measure pretty good and got the appropriate flange pattern spacer last time but it was just a bit off on all 4 holes.. makes me kind of curious if maybe they sent me 60x60mm spacing spacer instead of the 65x65 it should have been...
Crookedcat
