Driveshaft play? Something feels loose when taking my foot of the brake after a stop
It could be caused by the recent fluid change in your transmission. Try increasing the transmission fluid pressure and see if it has an impact on it. Tighten the cable that runs from the transmission to the throttle body an 1/8th inch or a little more and see how that affects it. That cable is NOT a kickdown cable. It is an adjustment for the fluid pressure in the transmission. The redline fluid may need a little higher pressure in the torque converter. I had this same issue when I switched to Castrol Synthetic in my tranny.
I don't like this advice because if the Op is not very knowledgeable he could easily break stuff by doing what you suggest. I do not know if this is wrong /right but seems wrong.
patnewton
