Dual battery setup
filoufil
Hey T4R,
I've been planning and buying parts for a dual battery setup for a while and I am finalizing the plan before I buy the cables.
I am trying to make a beefy setup because I would like to use my winch with the batteries in parallel so I can share the load between both batteries.
That's where my knowledge falls short and I am unsure of what size the cables and fuse should be to handle that much load. (For reference, my Warn Zeon 10-S platinum spec sheet is stating that at full 10,000 lbs pull, the load could be up to about 400 amps)
My plan is to use 2/0 AWG for both positives and negatives and using a 300a fuse. I am also planning to upgrade the OEM ground to 2/0 AWG.
Here's the schematic of my planned build:
A couple points:
-I would be considering upgrading the alternator in the future, but in the meantime, I will be using a battery tender once in a while.
-I have no plan to purchase a DC-DC charger for now, simply to not overcomplicate my build.
-I am using, and already installed, the shrockworks dual battery kit, their ACR and fuse mounting tray and their power distribution module.
-I realize that 2 AWG is probably overkill for my bussmann relay box.. but I already have the 100 amp circuit breaker in hand and it would be overkill for 4 AWG cables
I would greatly appreciate tips and comments before I commit to buy my cabling and install it all!
(Thanks to those that already helped me out in private message)
I've got the exact same setup except for the winch. Ended up running 1/0 AWG with 200 AMP fuse to connect the batteries to the ACR and ground. I went a little bigger because it's kind of a long run around the back of the engine and I wanted as little resistance as possible to the power going back to the house battery since I'm trying to not upgrade my alternator.
I did run 4 AWG from house side of ACR to the 100 AMP fuse on the power distribution module.
Planned on using the Blue Sea Remote Battery Switch to bypass the fuse for a winch later but ended up putting something else behind the grill.
Good luck.
