Dual Compressor Mount for drivers side engine bay?
TerraCrawler
Does anyone make a mount for the ARB Dual Compressor that goes on the drivers side of the engine bay (near the fuse box), but that can also hold a bottle as well?
The Slee is the only driver's side one that I'm aware of. No tank mount option. It's very tight over there. Hard to imagine an air tank fitting anywhere.
maybe i can mount the compressor there but put a tank in the back, i want to run a chuck out there anyway.....tank can go almost anywhere, hidden and out of the way, just need a mount
Somewhere on the forum there is a post describing how to get a 5 gallon tank to fit in the drivers side wheel well. It is cavernous up there above the fender liner.
You may be able to get the tank in there with the Slee mount but it's pretty tight. I am using the Slee mount with a twin ARB compressor and all I'll say is even with just that and no tank between it and the firewall, it's a tight fit. Especially if you want to be able to wire things through the driver footwell firewall grommet. My car is in the shop until about mid week. If you want some pictures I can post them in a few days.
I've been looking at the slee mount and I seriously doubt you can get a tank in there with the cable harnesses and fluid reservoir there, unless it is a .5 gallon tank or something. Wheel well is the way to go if you can figure out how to fab up a mount.
Found the link, here is a 2.5 gallon tank up in the wheel well.
http://www.toyota-4runner.org/5th-gen-t4rs/127366-mounting-viair-2-5-tank-possible-option-okki.html#post1206307
BANDI makes the pass side mount with a tank and he recently posted on instagram he is working on a driver side mount but no tank. The tank will have to go behind the bumper or near the spare tire. Are you set on it needs to be driver side?
seltzernator
