Dumping coolant and trans oil
jimmyrecluse
I noticed a small oil leak a week ago and then a few days ago I started smelling coolant, could not find where it was coming from, the radiator was still full at that point
This morning, when I started it up, it spewed transmission fluid all over the ground, appears and smells like transmission fluid. Also the coolant disappeared, radiator is empty and it appears to have sprayed somewhere above the coil packs - the top of the intake hose and coils are all wet. The transmission fluid appears to be leaking from above the transmission near the dipstick
Seems like there's a line somewhere that broke, anyone deal with this before?
PS doesn't seem to be the head gasket.
The engine oil is clean- no water
if the radiator is empty and the transmission is blowing off excess pressure out the breather or dipstick?
is it the original radiator?
I would
drain the radiator and see what is all in there?
drain the transmission and see what is in there?
visually check the trans cooler lines (I'm assuming you have an auto if you have a trans dip stick)
visually check the oil cooler coolant lines on the drivers side as well. they could be leaking but why ATF seems involved points to pink milkshake type of event.
Nope. Clean trans fluid and the water is just gone - looks like it's sprayed over the top of the engine, passenger side of the manifold
how about the 2 coolant lines that go thru the throttle body? they are attached and no cracks?
it's very strange to just lose all the coolant and have it spray out... something must be cracked?
I just filled it with water and started it and let it ran, nothing is leaking anywhere!
I suspected coolant lines around the throttle body, I will take a closer look
Both the engine oil and transmission fluid are clean, I just had those flushed and changed a month ago.
I suspected transmission fluid/coolant lines, broken or maybe loose
Coolant lines around the throttle body can't leak transmission fluid.
Are you sure it's transmission fluid?
Dexron automatic transmission fluid doesn't really have a smell to speak of.
Doesn't really smell, it looks exactly like what is on the trans dipstick. That's why I thought it was transmission fluid
It was just Spring out of the back of the engine area, like above where the transmission and engine bolt together
It's a slight reddish color,slick like oil
toyota red coolant
right I'm assuming it's toyota red coolant.
dude ATF stinks bad at least to me.
I mean radiator is empty? trans fluid is good and full? this makes me suspect coolant 100%.
So I just check the transmission fluid, what is leaking is 100% transmission fluid, the water in the radiator is also missing
I had green coolant in her this time
The transmission fluid is super clean and as you'd imagine just slightly low. So that's what I have, transmission fluid spewing from what looks to be the back of the engine above or on the upper side of the transmission and missing water
I recommend putting coolant dye in the cooling system, refilling the cooling system, and looking for the source of the leak that way. 1 leak at a time is the best way to go about it; starting with the worst leak first. You'll need a UV light to see the dye. A cooling system pressure tester would be helpful as well. If you do use a cooling system pressure tester be careful not to exceed the pressure stated on your radiator cap or you will cause damage to the cooling system components. Also, coolant has a very slick oily feeling to it. It's possible that you are only leaking coolant.
That makes sense since the only coolant hoses that are that high up in that area are the throttle body coolant lines and the heater hoses/valve on the firewall.
Should be an easy fix.
