Dyna Beads
Did copper BBs on my 37s.
Worked OK. Helped balance them out, but didn't work 100%.
That's because the 37s have a gooey crap inside them, and the majority of the BBs didn't go anywhere, just sat in the goo.
As long as you're not running goopy tires, you'll be fine.
I've got 'em. Wouldn't get them again. I put them in my 265/70/17 Cooper Discoverer AT/3s (and they're small for a 32" tire; they measure about 30.5"). Steering wheel was shaking all over the place above 55-60 mph. Had to get the wheels balanced with weights anyway.
They're good on 35"+ tires. Most tires smaller then that aren't going to be hard to balance. A lot of guy that run them have tires the aren't molded evenly. I had them when I was running 44's on my old Jeep. When you get into larger tires that's the only way to go. I wouldn't put them in my 4runner tires though.
I have balance beads in my new 35" TTC's and they work well. Every once and a while I still get a little shake but it usually smooths out in a few seconds once the beads move around to find their spots.
Have 10oz in each of my 35s, like others have said, not perfect, vib around 55-60, then smoothes out. i would just do regular weights.
tyler_ross
