My 99 4runner has about 210k miles on it. I was getting an occasional miss or stutter that didn't stay active for too long. Seems it happened when it's warmed up. I decided to swap the coils, plugs, wires and injectors. I bought some cheap injectors on EBay for $60/set of 6. After installing everything and putting everything back together, I started it up. It would idle smooth but it now misses wildly under any throttle. I decided to swap back the original coil packs to check and see if they might be the cause. No change. I feel confident the plugs and wires are installed properly and I'm certain I didn't mix up the firing order. I checked that online and confirmed the order was correct. Could it be the cheap injectors? Today I brought my OEM injectors in for an overhaul. I'll pick them up tomorrow and see if they are the culprit. Anyone have any input or advice? Thanks in advance.
