Eclipse 5100 with sirius installation.
imprttuner88
Well not having sirius was really getting on my nerves as I have been a subscriber since 05'. I really didn't like any of the stock alternatives of getting sirius into my T4R so I went the afternarket route instead. I was in so much of a zone on installation 3 weeks ago I forgot to take pics of the install in progress, but here is the final results!
Radio:Eclipse 5100
I had a bit of trouble finding a sirius antenna with extra length local so I could do the install, but with my moms sporster unit I tried out at a local stereo shop a xm unit they had to see if the antenna's where as universal as they appeared, learned they are indeed interchangeable. Anyways, here are the antenna pics.
First pic shows placement
antenna1.jpg~original
This pic shows its location on the door, there is about 3/8" gap when door is opened.
antenna2.jpg~original
Shows how I ran the antenna wire into the grommet that goes to the underneath of the headliner. Where I put the wire under that grommet I added some clear silicon to prevent any leaks into the cabin area.
Wiring1.jpg~original
Shows the route I chose to tuck and hide the antenna wire.
wiring2.jpg~original
Pic of the Radio
Radio1.jpg~original
Another pic of the radio
Radio2.jpg~original
Where I cut a hole to feed thru the USB reader and flash drive.
USB.jpg~original
Nice Job!
Can you tell me where you got your mounting kit for your reciever? It looks really good! Can you control that reciever with your steering wheel controls?
I got the dash kit from Best Kits as well as the wiring harness.
I also was able to retain steering wheel controls by using a IR module from eclipse. Has a slight delay to it from the stock controls but it works well and I am very happy with it.
Gonzaga Lobos
