nserpa9248 said:first thing is to troubleshoot this, is unplug all the harnesses from the unit, and make sure the car is working fine, if you said youve now CUT the VSS wire from the BCM and stuff, you need to make sure that the truck is fully functional by itself, a NAV system SHOULD NOT be throwing a CEL or anything like that!
nserpa9248 said:ok as far as the VSS goes, page 135 of the operation guide, will show you how to check the VSS signal..
Now as far as audio "problems" what is going on?
As far as i know, the problems your having are
-Poor sound quality
-VOL TEXT popping up
just need to know exactly what were fixing...
nserpa9248 said:spider, not to sound like im correcting you, but he did mention that it sounds fine when he is parked, and the engine is not on...
I would imagine that the power antenna is hooked up,
BUT 1MZ-V8 i would still double check your other wires just to eliminate any other problems
