Ecotechne roof rack GROUP BUY!!!
Status
Not open for further replies.
How much does that ladder weigh?
How much does that ladder weigh? Looks heavier than the Gobi. The steps sit behind the flat outside panel section?
Update:
The rest of the 5th batch is on its way here!
6th batch should be following right after.
The 7th batch will close as soon as the spaces are filled even though they have already started production. I just need to fill them before I can submit the order.
As for the ladder, as I understand it's made out of aluminum and will be as light as the Gobi if not lighter.
Did you coat the 4 edges? Or only the front? What length did you order?
I think the side edges need it more than the front does. If you want to guestimate, about 16-18' should be just enough for front and 2 sides.
However, if you have Amazon Prime it's a better deal at: 10' - $10.00 or 25' - $15.99. If you buy 20' it's $22.99.
I've only got the front and crossbar edges done. You can put it on the side edges (which I may do in the near future), but I would only put it up to the crossbar mounting sections. That way you can always have the crossbars sit flush with the side rails. I only have the crossbar edges coated up to where it meets the side rail. If that makes any sense. With as cheap as this stuff is, I would just get 40'. You should be good to do as much or little as you want.
hi guys, i see a lot of you converting to using black oxide stainless steel hardware. black oxide is basically black rust...so it will rust. better would be to use black anodized or nickel plated hardware (if available)...or just spray paint the stainless hardware that came with the rack.
Now that 7 is full... How long to ETA?
Rorck,
Thanks for a great GB. Now that GB 7 looks to be full, how long should it take until we get delivery?
Thanks,
Stick
Darn it, when will these adjustments take place?? I'm in group 6.
RIGHT!? I'm in batch 5 but I don't think mine has been shipped yet, or at least cleared customs.. crossing my fingers and toes mine has the new tie down points and everything, that would be so much better. If not I may offload mine on local classifieds and re-order in the GB :) hahaha
Status
Ambrose67
