Eibach needs a stock TRD PRO in SoCal
Damn, apparently the PRO-LIFT-KIT springs doesn’t fit after the TSB#0094-20 fix. That’s really unfortunate since I wanted to keep the Fox shocks and didn’t want spacers..
Anyone know if they’re redesigning them? TIA!
they are working on it for TSB they already have the springs its going into production just got wait the new 2021 spring for the Pro will be the same
EDIT: We actually had one here this morning and have confirmed 2021 fitment. We will be finalizing part numbers and should be sending them to production shortly. I would anticipate a 10-12 week production period once the part number is released.
How are things progressing?
Does anyone know of any shops that have the front and rear (non TSB) in stock still? Been searching for months for these and it sounds like the ETA from Eibach to get more made is unknown.
Unfortunately I am in Canada and it's quite hard get parts up here.
Another member had posted they found a set on Tire Rack.
I bought the rear springs direct from Eibach about 6 weeks ago. The rears won’t change pre/post TSB.
I was able to find the front and rear separately from a vendor in Toronto named TDOT based on searching with the Eibach product number. The customer service rep was unable to verify if the springs were in fact the correct ones but I'm going to gamble on it and just refund if it doesn't work out...hope it does lol
This is one way to do it. We offer the parts as a kit and a'la carte. For reference:
2019 - 2020 TRD PRO, Pro-Lift-Kit springs
E30-82-071-03-22 = Kit
E30-82-071-03-20 = Front Pair
E30-82-071-03-02 = Rear Pair
TSB and 21' Update:
STOCK
PROTOTYPE KIT
mark@eibach-albums-sample-photos-picture60409-eibach-prototype-trdpro-4runner-21-kit.jpg
Current ETA will likely be sometime 4th quarter. We're doing our best to prioritize production and will report back with any updates on getting these moved forward. Thanks gang.
Finally got the springs and installed them today; added some 285 wildpeaks for good measure!
If you [Eibach] are out of stock, and an online retailer says "ship from manufacturer" are they also technically out of stock? (despite having a crappy website that lures you into purchasing? )
No UCA's. No trimming of any kind. All I did was add the springs, then the 285’s, went for an alignment and then remove the spacers because it was rubbing. They were able to get 2.4* for caster. Toe and camber were in spec. It drives straighter than it did from the showroom. I’m very happy with how it turned out. No idea if it will need trimming once I see it flex off road.
[MENTION=219032]DallasTRDPro[/MENTION] where did you go for your install? I’m near DFW. Thanks.
Let the front spring development begin! I'm kick starting this project for you guys myself.
I need your stock 2018+ Pro for a full day to measure in the next few weeks. Once the prototypes are complete I'll bring it back in and leave a set on your rig for free.
Who's in?
Ryan
Update on this release date for the new springs?
Several solid options in the area - Tread Depot in Mansfield, Goode's in Rowlett and Tandem in Haltom City.
* Tread Depot and Tandem can do an alignment in house.
Yes, that is correct.
JUST FYI,,, Their website is showing pre TSB spring in stock!!
Just ordered mine!
PRO-LIFT-KIT TRD PRO (Front Springs Only)
Yup, the NON-TSB springs are back in stock and ready to go! Right now it's showing the set of 4 is out of stock, but that is due to a packaging issue. You can order front and rear separately or give us a ring and speak to Tanner.
The new front springs are on the schedule for production, ETA is fourth quarter at the moment.
[MENTION=277772]mark@eibach[/MENTION]
Early or late 4th qtr?
I'm currently on a 10 month wait for the Pro-Coilovers + Leveling Kit/Rear Shocks from Eibach... I would be wary of ordering anything from them until they can actually produce the products they're selling.
Everywhere there's delays for parts not only Eibach. King shocks are 12 months or longer. ADS probably has the least amount of lead time right now.
There's a difference between someone saying "It's going to be 10 months to make these shocks" and Eibach saying "It's shipping out next month" every month for the past 10 months.
Unfortunately, Eibach makes the application I need at the price point that's inside of my budget. So, I guess I'll make like a mushroom, eat shit and be kept in the dark :roll:
What the difference between TSB and non-TSB springs?
Sorry I’m new.
Have a ‘21 Lunar Rock 4Runner and would like to get some more height with Eibach springs so I can fit 285s on there without a body Mount chop.
Sorry I’m new.
On 2020 PRO's the bottom of the front springs are ground flat. The bottom of the front springs on the 2021 PRO's are not grounded flat. As a result the shock+spring assemblies are different part numbers.
Some owners of 2020 PRO's living in cold climates experienced noises from the front shocks. Toyota issued a Technical Service Bulletin (TSB) for these owners where Toyota will replace the 2020 front shock+spring assemblies with the new 2021 part numbers. As a result, 2020 PRO owners who have had the TSB service now have the same shock+coil assemblies used on 2021 PRO's
premiumusedautoparts
