Eibach Pro-truck lift
What would be the resulting lift with about 120lbs added to the front?
Does it maintain ride comfort?
Using this post as a reference.
center of hub to top of fender measurements
I measured my 2019 Off Road (No KDSS) w/ an estimated 200lbs hanging off the front and Eibach Pro Lift, stock size 265/70R17 Falken Wildpeaks, and a full tank of gas. I get the following measurements measuring center of the wheel to the edge of the fender.
Driver side front = 21.75 inches
Passenger side front = 22 inches
Driver side rear = 23 in
Passenger side rear = 23.5 in
Stock Height is mentioned in one of the previous threads as being:
Front = 19.125
Rear = 22
Ride comfort is subjective to the driver. I find the Eibach lift makes the truck feel more taught over stock. Where before the body roll through the curves and nosedive on braking was horrible.
Now it's tight in the curves and nosedive is gone. I find it is still comfortable to drive on bumpy washboard unpaved roads and still is comfortable for paved road trips. I don't find the ride jarring at all. YMMV
Longest road trip so far for me is 4 hours each way - my home in S. Missouri to Kansas City.
In a couple weeks I'm driving to International Falls, MN for a family house boat fishing trip. That will be a 15 hour drive each way. We plan to stop in Minneapolis to get a hotel after about 10hrs of driving.
Edited to add: I kept my 2006 Nissan Frontier King Cab 4x4 w/ stock suspension. The Frontier is way more uncomfortable to drive (suspension-wise) compared to the T4R w/ Eibach. The Frontier drives like a brick. I can feel every bump in the road. Only thing I still like about it is the bed and acceleration. Punch the gas and it goes.
The T4R seems to lag on accelerating. I got a Sprint Booster recently that I need to install to see if that helps.
Edit#2 I'd look at your tire size / weight for ride comfort & fuel economy.
In choosing the stock size Wildpeaks my goal was to keep the tire weight as close to stock weight as possible. This has greatly helped my fuel economy - 18.75mpg average (hand calculated) and ride comfort. I do plan to try 275's 40k miles from now.
On my Frontier w/ 96k miles, I'm on my 3rd set of tires - P rated Falken Wildpeak AT3W 265/75R16's. Before that I had 10ply LT BFG ATKO-1 tires in the same size. The BFG's were a heavy rough riding tire. Going over a washboard road was ridiculous. They killed a good 4mpg off the truck. The softer Falkens ride way better - though the truck still drives like a brick.
Tire pressure is something else to consider for ride comfort. You might try airing down your 285's to closer to the door sticker stock pressure and see how it drives.
Thanks [MENTION=387638]Drobs[/MENTION]
So you’re getting close to the 2.75 Eibach states it would hit without all that weight. Interesting.
Did you set the spring at the lowest clip setting or did you raise it up one?
It's on the lowest clip setting.
Ordered this kit from summit last week for my 2012 Trail. Excited, but feel like I should be doing UCAs as well. Does Eibach still make a compatible option such as these?
Eibach 5.25480K
Any review's?
Sent from my SM-A205U using Tapatalk
Eibach 5.25480K
Any review's?
That kit works great for the money. Just make sure they are torque'd to spec.
Ryan - I placed an order through Summit Racing for this kit on Labor Day. Order status says shipping from manufacturer. Can you help me out with this? Do y'all have the lifts in stock to ship?
Sent from my SM-N950U using Tapatalk
I wouldn't mind knowing the answer to this as well. I placed my order through Shock Warehouse though but they said they were delayed getting them but it should go out this week. Nothing yet though and I have my appointment with the shop on 9/25.
FWIW I just looked at the item listing on Summit and it's giving an estimated ship day of 9/30 if ordered today. Not sure if that applies to us or not.
Currently out of stock. ETA is 9/27.
Toytec stocked up and they should have plenty of hand.
That's too bad. Wish Shock Warehouse was more forthcoming. Now I either have to cancel my appointment and wait or look for an alternative. Toytec would cost me substantially more unfortunately with tax, shipping and no military discount.
This was probably partially our fault. I think the original ETA was the 13 of September. We had a batch of bushings get delayed from our supplier and the completion date was pushed back.
No worries. Frank was really nice to deal with. He said he was going to reach out to you to double check but I passed on what I knew. I would definitely use him down the road. May have to go the Toytec route as ever since I put the aftermarket bumper on I hear a sound coming from passenger side and think it might be the stock shocks making noise from the extra weight of the front end. Haven't nailed it down quite yet.
