Eibach Pro-truck lift
Kinda sketch for me but they also responded quickly
Sent from my ONEPLUS A6013 using Tapatalk
Just for anyone that was wondering. I purchased through them, beginning of August. Payment went through fast, they took about a week to give me tracking information. Waited the ~21 days they claimed it would take to receive the item and there was still no movement on the tracking. Reached out to them several times, and they just gave me the run around with "I will look into it" or auto replies. It was not until I opened a claim with ebay that they started acknowledging the problem. They then claimed the item was lost in shipping. The claim ended up timing out and ebay stepped in and refunded my money. They then somehow changed my negative feedback to a positive feedback and change their account name.
TL;DR: Was likely a scam, ebay stepped in and protected the buyer
Toytec Lifts sells the Eibach kit with tophats already installed. Toytec is expensive compared to everyone else. I tried to give them my business but it didn't make sense for me financially.
Regarding airbags, I found lots of good info on this board by using the search terms: 5th gen air bags for towing
https://www.toyota-4runner.org/gsea...ch-pro-truck-lift-75.html&ss=8609j12887019j14
Firestone looks to be the way to go.
If I find myself needing to tow my boat cross country again, I'll invest in some firestone airbags.
Yeah I know about toytec but I’m assuming they just use a stock rubber top hat, I was wondering if anyone sold a polyurethane upgraded one.
For the airbags I just wanted to know if the airbags for the stock suspension would be the correct size for the Eibach springs since they are taller I would think you would need a different kit. Thanks
I tow from time to time too and IMO it just is what it is. It's not often enough to try and come up with a solution for an hour drive each way every month.
The rear adjuster we are working in will help, but would you jack the rear of your rig up and manually raise the rear just to tow a boat?
OD of the rear shocks is 51.5mm.
Ryan,
Can you advise the Eibach rear shock length and inside diameter?
having those dimensions Fred and I could call Firestone to get the correct airbags.
Coil-Rite
800-888-0650
Thanks.
Got the body mount chop, fender liner mod, and a little trimming on the front bumper done. Now no matter what i do there is no rubbing!!
img_20191115_141844005-2-jpg.34863
We're only making one spring for it. We have a target height, but we have not test fit yet.
Would you be interested in something that leveled the front, or something a little taller that would allow you to raise the rear too?
Ryan, just my .02...
Given a choice on the 2019 TRD PRO fronts... 1-2 inches of additional lift and about 700lbs on the coil would be ideal. I also understand that may not be possible on the FOX TRD PRO units.
Also, how will your springs react to the different lower perch heights on the FOX units? or am I overthinking this?
Thanks !
2001ATL
