[EIGHTEENs] FN Wheels BFD
^^^ Any rubbing with that size 275/65/18 on stock suspension? Truck looks amazing.
Thanks man!
On stock suspension, and the fact that his is a 9" wide tire, there is a small amount of rubbing with no modification at full lock. I moved my fender liners forward, and pulled my mudflaps back, and the rubbing is gone (Full lock, both sides, forward and reverse). There is not a huge amount of clearance, but no issues either way. If you wanted to create a little more clearance, a quick trim of your bumper cover would clean that up without issue.
Finally installed my FN BFD's... I'll post up pics in a couple days. I had some questions for others with the same setup.
[MENTION=102063]nosamk[/MENTION] What PSI do you run your tires at? Did you also get rubbing on the front left tire on the back panel? if so, what's the fix?
Any one else please chime in...
I'm running about 38psi
I get a little bit of rubbing in full lock in reverse. otherwise not really.
I did the innner fender liner mod and it helped a lot
Resurrecting old thread...just ordered some FN BFDs given the blowout pricing for the current flow formed version before the latest version with flush center caps arrive.
Given a 1.5" lift with Bilstein 5100s F&R, with Toytec springs on the rear; would there be any rubbing issues with tire size 275/65/18? I"m thinking Toyo OC AT3's at the moment.
[MENTION=75328]DannyLlama[/MENTION] thanks for answering the BFD questions!
johnnya
