mikebontoft
actually that makes more sense to do it that way.
Yes, switched ground is ideal but OP wants to turn on aux lights with backup light. Backup light switch switches power (I know toyota engineers are not perfect)... Its not wise to switch power anyway. You should always switch a ground when possible.
I personally always use this diagram.
Installation Instructions for KC517 Backup/Flood Kit
It has worked for me in several reverse light installs. The "optional switch kit" mentioned is just a switch, fuse, and wire.
Thats works and is wired exactly same as Mikes and my schematic on slave mode, BUT KC lights setup uses the switch to carry load current when manually turned on. OK if you're alwasy sure your switch will handle your load current.
Ground side switching for the relay, not the light. The relay can be put where ever you want. Then run your light power from the relay. No need for a 12ft ground.
Same thing applies for 12v signal side of a relay. Just let the relays do the grunt work. This way he can upgrade the lights to what ever the wire can handle and not have to be limited to just leds or low draw lights.
...Now introduce ground side switching and you'll be running another ground...
Yep, advantage of relay; Capacity's already there.Then run your light power from the relay... Just let the relays do the grunt work. This way he can upgrade the lights to what ever the wire can handle and not have to be limited to just leds or low draw lights.
Yep, To convert stock reverse light switching to switched ground would require extra parts. too much trouble like I mentioned ^^^... Not possible without the use of another relay.
any update on this? how'd it work out for you?
