Electrical issue with door locks, need help
JeratBP
Member
Not just my door locks/remote but also the time display above the heater controls.
The issue started with my door locks/remote. I would try to unlock/lock the doors and get a single short chirp noise like the battery was going dead. Id try unlocking the doors and get a similar chirp. Different instance, after starting the vehicle, the time display would reset back to 12:00, one time it reset to 10:00.
This morning, an issue with door locks. I unlocked all the doors with the button on driver side and the rear driver door stayed locked. Tried a couple times and used the remote to lock/unlock doors, same single chirp issue.
Anyone have this issue before? Is it time to replace my battery? If so, I’ll search for a good replacement.
I haven't had this exact problem but first check your battery connections, make sure everything is making good contact and tight
I took it over to my local Battery Plus store, and the Duralast tested at 120 cold crank amps.... So it’s been replaced with a Duracell 24F with 700 cold crank amps.
Jhunt
