Electrical Issues - A/C Controls & Turn Signals
TrailHunterBen
How's it going everyone?
I'll Jump right in and say that I am new to 4Runners and am really hesitant with some of the things I ask on here because I see how some people get roasted by other members... But, I am in need of some real help and have searched high and low on here to try and find a solution to my problem but only found posts regarding 3rd gens and not 4th gens.
Here is my rig; 2005 Toyota 4Runner V8 with the limited options/package.
I am having some really annoying electrical problems and it started right after I installed new headlights, taillights and a new aftermarket HU.
There seems to be two major issues right now: :confused:
1. My turn signals will not work but my hazards will.
(When I was installing the new HL and TL I tested each one after install and they worked great, I was getting hyper flash since the new headlights have LED's in the turn signals but that was it.) Now they will not activate at all when I hit the toggle up or down.
2. My A/C control panel will not function at all.
(Now I noticed this after installing my new HU... So I went back and made sure all the wires were in the right place and plugged in snugly, but I still wasn't getting any controls back. I even reinstalled the old HU to see if I missed something and it was tied in there somehow but still nothing worked.
Before anyone weighs in... Yes I checked the fuses, I checked the wires and I checked the relays. Well I checked the flasher relay under the fuse box and it looked fine. Is there anything I am missing, should try or do?
I would really appreciate any info.
There are also no codes being thrown that I can tell.
Just going through the forum, I came across a thread with your LED swap hyperflash issue. Although the flasher relay in your fuse box is fine, you need a different type of flasher relay that can handle the LED. I can't remember parts number but I believe it's a European flasher relay. Search it on the forum.
Edit: I think this is what you need but research to double check. Parts: CEC Industries EF35 Electronic Flasher w/o DRL
Well... to trouble shoot the hyperflash issue, just re-install the original bulbs, or get a halogen equivalent. At least that rules out the bulb. Its a trouble shooting step...
As far as the other problem... perhaps a damaged connector/terminal/wire during installation. Perhaps someone damaged the HVAC control module itself. If I was at a loss and wanted to throw money at diagnostics I would either take it to the dealer and pay them for one, or maybe throw a part at it like a new control head.
Or you could just have rodents living in ur car feasting on your delicate electrical system...
Edit:
Also... its the internet. Worry less about your feeling getting hurt or what other people opinions are. Generally speaking any question here has some learning information/potential.
That's not it. If it has DRLs, nobody makes a LED-compatible version of the 20-pin flasher relay. If it doesn't have DRLs, it's a CF18 / LM449 8-pin flasher relay.
[MENTION=152323]TrailHunterBen[/MENTION] - what LEDs and taillights did you install?
So thats a good point. I did/do have DRL's and they don't make a "LED Compatible" relay replacement. :frusty:
I've read that a few people will solder resistors in line on their existing relays for a fix and that could work.
But my issue isn't with the hyperflash, it's that my turn signals wont work at all.
(Side note; I'm not worried about my feeling getting hurt. I realize its the internet, but I just wanted to preface my question with that bit of hesitation.)
Check the 15 amp IG1 fuse - looks like its the only thing shared between the audio system and turn signal/hazards. If it's blown then blows again upon replacement, unplug the radio before replacing it again.
Just pulled that fuse and saw it was blown! I will have to replace it in the AM, I hope that is it. Thank you for pointing that out. I must have been blind when I pulled them all a few days ago. :thumb:
... am really hesitant with some of the things I ask on here because I see how some people get roasted by other members...
Ignore the roasters! :)
I vote you make a build thread... I'd like to follow it :)
Looks like you have a lot of experience and are capable of building something awesome!
Undo the dimmer wire on the radio. Or make sure you are using the correct one. Most interior light fail happens when using the wrong dimmer wire
Solved
Thanks! I appreciate your encouragement, I will be making one eventually. I want to have a catalog first for most of the things I'm doing.
As to this thread! I found the short! It took some hunting and some trial/error.
In all, it came down to my passenger side tail light. There was a wire smashed by the top nut that tights the light to the body and it was grounding the hot reverse wire. Ergo shorting that fuse and everything tied to it.
Thank you for y'alls help!
MMJR_T4R
