So I just found out that my used 4runner , has some type of parasitic electrical problem. Something is draining my battery power when my truck is not running. Its taking about 1 volt out of the battery per 24 hour period.
I took the lighter out of the light socket...the radio is turned off, no lights are on inside or outside of the vehicle , the small LED date/time window is not lit up when the vehicle is off....
any idea what could be draining power from my battery ?
I just bought a new battery, cause the battery that was in the 4runner when I bought it, went down to 4.8 volts , over a 6 day period when I did not start it up...
if I cant figure this out, then I guess I have to put a inline cutoff switch on the positive side of the battery terminal, and manually disconnect it whenever im done driving...that would be a pain in the butt.
Something does seem screwy with the lighter output....I have 1 of those solar lighter battery chargers, that plug into the lighter input, and keep the battery fully topped off , when the vehicle is not running. I plugged that into the lighter socket, and then tryed to measure the voltage on the positive and negative battery cables { unhooked from the battery} , and it was reading only 10 volts , when it should be reading about 20 volts, which is how much the small solar panel puts out to keep the 12 volt vehicle battery charged up.
Ive used these small solar panels before on other vehicles and they worked great via the lighter socket...so something is odd with this 4runner.
