engine check light on...HELP
97runnerBC said:
so my '97 has the odii computer? Also, I'm kind of confused.....even though my check engine lights off I should still get the codes pulled??? everything feels fine in my car....except for this one morning after the check engine light turned off; there was still that rumble/vibration in my car. However, once my car was warmed up it went away. ahhhhhhhhhhh it sucks not knowing about cars!!! thanks for the constant replies back.....L8
P.S. I checked my gas cap....it was on right.....but it was only when I turned it that I heard the 'click'.........
In your case, maybe the engine light came on because the gas cap wasn't on tight enough. Be sure to turn it several clicks to be sure it is on tight. How many miles have you driven since the light went out when you reset the battery?
Unfortunately, I don't know about the vibration aspect. Must be unrelated to the engine light if it still exists after the light went out. Hopefully it's nothing serious.
chasebradshaw
