Engine died
Saved
I would like some input as to where to start looking for my problem. Yesterday I was driving along in my 92 V6 and it suddenly died. It was like someone turned the ignition off. No sputter or anything, it just quit. I had to tow it home and now I need to start looking to find the problem. Suggestions?
Sight
Sound
Smell
Feel
History
You will not have "sound" if the fuel pump quit.
You may "see" oil on the ground if a broken connecting rod is protruding thru the block.
It acts like an electrical issue. It still turns over but will not start. It acted like I turned the key off.
Any luck on a solution? My truck did the same thing to me yesterday. I have a 2003 4Runner V8 Limited.
Nothing yet. It has been rainy and cold here so since it is out in the open I will wait until things clear up to get after it.
Check all your fuses, inside and under the hood. Simple but oftentimes overlooked.
Check the fused links too.
This probably isn't the same thing, but on my '98 I was driving in town, pulled over and made a call, and then tried to start. Nothing happened, and some of the electrical things in the cab didn't have power either. I was a mile from home, and ended up getting towed by a passing Cherokee. Eventually the next day I found one fused link under the hood that must have oxidized a bit too much. I just found it strange that it was working, and then 2 minutes later wasn't. Others with similar strangeness have found loose or broken wires.
That doesn't mean that's your problem. But it has caused me to carry a spare volt meter back there with the jack and non-FSM SM. (FSM stays at home)
Check ur timing belt
I forgot about that one. I bought this 3 or 4 years ago from a family that took it away from their teenage son who was running wild with it. I have no idea how many miles are on it so that may be the problem.
Djd you run out of gas?
No. The suggestion of the timing belt is probably correct. That is exactly what it acted like now that I think about it. I still have not looked at it because of the weather. Most likely I will do that tomorrow. If it is the timing belt I am not looking forward to it. I do appreciate the suggestions.
With a broken timing belt the engine will crank faster than normal due to loss of compression. Some valve covers you can see the cam through the oil fill cap hole.
Shine a light in the cap hole while a assistant cranks it over. See if you can see something moving.
Things to check:
1) EFI relay, on passenger side of engine bay
2) fuel
3) battery , alt
4) t-belt
Best of luck with it.
regards
seltzernator
