Engine Problems
rrlance
I bought my 4Runner (3.4L) back in August and absolutely love it...well until the past month or so when I started having some problems. I'm not much of a mechanic and would appreciate any advice on my problem.
About a month ago, it started running "rough." The very next day my Ultra Gauge showed error code P0303. Look this up and said misfiring cylinder. No problem because I had already purchased NGK plugs and wires but hadn't gotten around to replacing them. Installed them and noticed that the plug in cylinder 3 had a burnt streak on the porcelain. I also moved the ignition coil from cylinder 3 to cylinder 1 in case it happened again. All seemed well afterwards.
A couple of days later though I get another error, P0301. Must be the ignition coil since it moved cylinders. Bought a new Denso ignition coil and a new plug. I figured I might as well change out cylinder 1's plug again. Maybe not necessary but for a few dollars why not.
After all of this, the 4Runner was running great except that my gas mileage dropped. I was getting around 22mpg on the highway and now I was getting about 17mpg. I ran some fuel injector cleaner, put in a couple tanks of premium Shell gasoline, and reset EFI fuse. It then jumped back up to 19mpg so I thought it would get better over a few tanks but it was actually gotten worse.
Fast forward to earlier today. I drove it to my mailbox while it was dark and noticed a faint amount of smoke around my passenger side headlight and a burning smell. I popped the hood and saw smoke coming from my headers from an oily residue on it. This is where my engine skills stop and I need advice. This oily residue is all around the engine where the intake manifold connects to the engine. It is on all sides of the engine. I noticed this before but I wasn't having issues so I just discounted it. I took a picture with my cell phone a few minutes ago.
https://www.dropbox.com/s/jbuquew4b3hol5m/2013-01-11 20.13.37.jpg
What would be causing this oily residue on the engine? A leaky gasket??? Would this cause my gas mileage to drop? My oil dipstick shows it is full, and the oil looks new.
I know this is a long write-up but I really do not want to put my 4Runner in the shop if I don't have to. Any ideas?
have you checked your radiator fluid level?
Any white smoke coming from the exhaust?
How does the oil look- no milky look?
As for the oil leak, that looks like valve cover gasket. You can try checking the bolts on the valve covers and maybe re-tightening them first.
Be REALLY careful if you choose to re-tighten. The valve covers crack easily.
Do not try to tighten them without a torque wrench!
Agreed. The torque specs are pretty low on these valve covers. OP - I'd leave it alone til you get it fixed. Tightening with a bad gasket can put too much stress on the valve covers.
Thanks for the replies. I feel a lot better now. I'll probably hold off on fixing it for now since it isn't a daily driver.
Does anybody have any ideas why my gas mileage dropped though? Dropping from 22mpg to 20mpg isn't significant but something changed that caused it. It started when I had a misfiring cylinder. I had a friend say my catalytic converter might have issues now since I drove it on a misfiring cylinder. Something about gas not fully burning in that cylinder and then going out the exhaust.
FYI, both the oil and coolant look normal, and I am not blowing white smoke out of my exhaust.
Your cat could suffer - but that alone wouldn't lower your MPG. Hell if you had no cat you'd get BETTER MPG. If your oxygen sensors bit the dust, your MPG would go down - but you'd have a CEL.
If you are still misfiring, you would see the MPG drop. Also you may see mpg drop if you just ended up switching to winter gasoline as the gasoline mix in the winter tends to result in lower mpg than the summer mix.
2001ATL
