Engine swap '95 to '94
'95Newbie
I have a '95 4Runner V-6 4WD with a dead #4 cylinder. I found a great deal on a '94 V-6 so I am going to have it put in so I can re-build the original and get as much out of it as possible. My questions are WILL a '94 fit right in a '95 (both are 3vze)? WHAT main concerns should I make the machanic aware of? WHAT is the best re-build kit for the 3vz3? Any and all help is appreciated.....PS. Body lift info needed also...HELP A FELLOW RUNNER!
It should all be plug and play. Get top end kits from RockAuto, about half the price of napa. Feltpro is good. Make sure to put a little RTV on the valve cover gaskets to prevent leaks.
Body lifts lift the body off the frame. They are a cheap way to fit bigger tires. Best used with a drivetrain/gas tank lift.
Welcome to the forum!
Hyde is right its should be plug and play and rockauto.com is the best place for parts when your planning a repair.
Rialm
