Engine Tick
Need more info about what model you're driving....V6 V8 etc.
When was the last time you ran a bottle of fuel injector cleaner through a tank of gas? I use a can of Sea Foam with every oil change.
The only time my V8 has ever ticked was shortly after I bought it before I had a chance to look into the maintenance. I found it was the cheap the gas and it only did it when I put the pedal to the floor. I haven't heard that sound since being on top of my engine cleanliness and maintenance.
Its the V6, yeahh i should give the seafoam a chance, it varies rate with accelleration. i was thinking hopefully this would be the problem: http://www.toyota-4runner.org/4th-gen-t4rs/42542-v6-tick-tic-tap-noise-reduced.html
