Erik's rust repair - 1st gen
slacker
Erik's rust repair - 1st gen + 5Vzfe, 3.4L install
Erik brought us his runner to repair ..
previously , some other person had cut the rust out , and made it work for a few years , but now time to do it right !
SSPX2539_zps24513d10.jpg~original
SSPX2543_zps5bb5d019.jpg~original
SSPX2542_zps4db13ceb.jpg~original
and the cuts on the outer wheel house ..
SSPX2540_zpsa85981b6.jpg~original
6b3c7649-d5ad-46d5-a8e7-0461c1a792a6_zps327b376b.jpg~original
got the old sheet metal off .. and here's why I recommend doing the whole panel instead of a patch
SSPX2546_zps87b811d9.jpg~original
clearly you can see the rust !! also .. it allows you to clean and repair the complete inner .
because of the previous owners "repair" , we had to replace the outer wheel house on both sides
SSPX2547_zps56f36186.jpg~original
SSPX2549_zps897ded4b.jpg~original
and with everything all cleaned and prepped , time for some POR 15
SSPX2551_zps00ce33b6.jpg~original
and wheel house "glued"
SSPX2553_zpsfe5df4e5.jpg~original
with everything cured , the rear 1/4r panels are now fit and epoxied into place
SSPX2561_zps5f119172.jpg~original
also got the fronts on
SSPX2562_zpsb6a6a9c7.jpg~original
SSPX2573_zpsd40fe93c.jpg~original
and last but not least , our new rear inner panels installed
SSPX2572_zpsef1d553c.jpg~original
SSPX2574_zps9d031880.jpg~original
and everything back together today ..
SSPX2577_zps79a504a6.jpg~original
SSPX2578_zps180e9019.jpg~original
Erik picked up , and another happy customer
SSPX2580_zps9af49a1e.jpg~original
SSPX2581_zps3cbc7cab.jpg~original
Thanks ..
Erik also purchased some of our L trims and a smoothie cowl , so he will be installing them himself
looking pro [MENTION=3959]slacker[/MENTION] I checked out the glass site too give me lots to plan for in the future.
how did you separate the outside sheet metal from the frame? on mine it looks to be just pressed together somehow...
the outer skin is spot welded. I usually use an air chisel to cut the main section of the panel off first , then drill out all the spot welds .
looks great! how do you like the POR15 stuff? does it actually work?
I really like the POR15 , I have had great success with it .. you just have to follow the directions .
I even had some left over one day when I was building my Trekker , I decided to use it on my rear bumper . I never even washed it off , and 6 years later , and sun faded , it finally broke threw in a few places .. just did it again with a little left overs , and should last another 6 years ... and this was with absolutely NO prep
oh wow. i will definitely be getting some haha
Erik is booked into our shop in June .. 3.4L swap ,+ our new headers
SSPX2664_zps5abb1b4e.jpg~original
except he is going with our VHT painted black set ($450.00)
Awesome work as always Slacker. Now if only it was my 4runner rusting and crusting to death instead of my BJ60...:canada:
busy working on Erik's engine
SSPX2686_zpsef53c34e.jpg~original
SSPX2687_zpsbb35d80b.jpg~original
Erik has opt. for our black painted headers , as well as our new clutch , filters , belts , plugs and t/belt and water pump .. so busy getting everything prepped and cleaned before the install
SSPX2691_zps0f166774.jpg~original
more cleaning and prepping today .
got a bunch of parts blasted , and painted , including the oil pan .
SSPX2719_zpsdbfbc362.jpg~original
also got the bottom end buttoned up . drilled the dipstick , tapped the old dipstick hole , new pickup , and attached the clean pan , oil pressure sensor , oil filter
SSPX2720_zpsd5bdaf81.jpg~original
SSPX2721_zpsaa894884.jpg~original
flipped it back over , and started the top end .. as well as new water pump and timing pieces
SSPX2722_zpsd939d610.jpg~original
and added some powder coated pieces :)
SSPX2724_zps8d92eed9.jpg~original
so now engine is ready .. couple of pieces to add , but I think we're ahead of the game :)
SSPX2727_zps6677a03b.jpg~original
notice our new headers :)
SSPX2728_zpsae850a33.jpg~original
SSPX2729_zps7ab954e8.jpg~original
basically ready to install
