Exhaust options
GHARP57
If this post needs to be elsewhere please move it.
So If I wanted to go with a catback exhaust on my 99 4runner. do I have many options? I would want to keep the o2 sensor in it if possible. I was 2 weeks late on getting a toyota trd exhaust which would have been perfect.
Thanks for the input!
most people run flow master 40's on their 4runner. I run straight pipe to my flow master 40 I do have my o2 sensors but I get CEL codes thats cause I have no cat.
Borla makes a great exhaust & that's the one I wanted but funds at the time of my old muffler getting a hole in it led me to the Pro Flow from LCE Performance. I also added a High Flow Cat to my Headers so that my entire exhaust is high flow. Call before you order to make sure you get the right year & engine.
http://www.lceperformance.com/Exhaust-Systems-s/1542.htm
You and me both! Just called up some local shops this week to get quotes and such.
Let me say this: getting a new exhaust fabricated from a muffler shop is cheaper than buying a full exhaust online. As in up to $300 cheaper. For a stock 4Runner, you can get new piping (go up 1/4 if you want) and a new muffler, such as a Magnaflow or Dynomax, starting at $250. Some will even put a tip on for that price. Don't bother with mandrel bent piping or nothing like that, you'll never see the difference on a stock engine. Also, any muffler shop will be able to weld in a new bung for the O2 sensor really easy.
Here's what I've learned after searching online about muffler brands (and talking with exhaust shops). All the major brands, Magnaflow, Borla, Flowmaster and Dynomax will increase flow and sound over a stock muffler. Flowmaster has the most restrictive out of the four, meaning less HP gains. The other three are pretty much completely equal. Dynomax is louder than Borla and Magnaflow, with Magnaflow being the lowest frequency.
As far as types of mufflers, the three (Borla, Magnaflow and Dynomax) have a "touring" or "economy" version that reduced the sound the most, but still louder than a stock muffler. Borla and Dynomax also have "performance" mufflers that do nothing at all for performance on a stock 4Runner, only make it louder. This is not my cup of tea so I'm staying away from those.
I've got a supercharger so I'm a little more picky. I have a much higher exhaust flow rate (my 4Runner spews exhaust like no other) so I am looking at mandrel bent piping as opposed to crush bent for a performance gain. I am also building the engine up to hit near 300 hp at the crank... so it's a different route for me.
Im running a JBA cat back exhaust, with LCE long tube headers, and I highly recommend it!
the exhaust might be a bit loud for you, if you don't want to turn heads as you roll down the street.
EDIT: Also I would highly recommend keeping the cat if you roll the rear window down, if you remove it, you will REALLY smell the exhaust from the back window.
I had this exact muffler on my last 4runner and it sounded amazing. It's essentially the exact same thing as a 14" Magnaflow for $40. Toss your local muffler shop another $30 to get it welded on, and you're going to be very happy. Catback just seems like a waste of money to me. You'll never extract that much power from these without going forced induction, just do it for the noise.
If I wasn't doing straight pipe after the swap, I'd get one welded up on this truck as well.
Link isnt working for me. what type is it?
I gots the JBA as well but it's still sitting on the floor in my office. I hope it's not as loud as you're making it out to be. I really don't want to be an obnoxious truck guy. Cheaper than the Borla catback. Normally I wouldn't bother with the exhaust but I'd like to get more performance from the supercharger. I'm keeping the stock cat for now. We don't have emissions stuff here so I can get rid of it If desired.
I think my headers really make my exhaust louder. for my truck the JBA has a deep drone going up a slight hill on the freeway, idling its semi-quiet but when you get on the gas it makes some noise! Ill try to get a recording asap, I am out of town right now but when I come back ill try to get it up.
I guess that's what to expect from a straight flow "packed" muffler design.
(sound goes right through just being deadened and deepened)
I pulled the trigger on a Borla Pro XS 40665 (2 1/2 inlet/outlet). Lots of sound clips online and other member recommended it so I'm sold.
Downside is mandrel piping starts at $375 alone... dang. That's pricey, I may have to change my plans. I can get crush bent piping for under $200.
Anyone know how much MPG's they gain from a new exhaust? If it's enough, it'll pay itself off in gas savings for me in a few years. Much easier to convince the wife to let me get it if it saves money in the long term (like switching to AMSOIL and doing my own oil changes :)).
Get rid of the cat & add headers that's where your bottle neck will be.
Anyone have a link to a set of long tubes for these trucks? I'm a performance junky and an exhaust junky and need to get this thing sounding good and running good. And next year I'll get a supercharger.
My stock muffler was whistling so I got a flowmaster 50 series welded in with the stock pipes. I think it sounds nice. Before the break-in, it sounded kinda lame when you got on the pedal but what can you do? It is a v6. Ultimately, it sounds pretty good. A little drone at ~2k rpms but not a terrible amount. I paid $180 which was great compared to the $450+ I was quoted at another shop for a cat-back. I don't think cat-backs are worth it unless you're running a supercharger and are really trying to force some ponies out
DionicioLives
