Extended mud flaps
MrRoo
I took off my running boards for several obvious reasons. The factory front mud flaps seem to not stop much from splashing all over the rockers. Are there any available that are longer? I can make something easy but would rather spend my time on other stuff.
There's a Tacoma in my parking garage at work that has big rally armor universal mud flaps bolted on, it looks okay but surely keeps his truck cleaner.
I also noticed the OEM mud flaps are 1.5 inches shorter than rear and not as wide.
I purchased after market fiberglass re-enforced mud guards.
I made a pattern using card board . set the position and the OEM holes.
put pattern over the new part , drilled holes then installed using the same OEM fasteners. now it is wider and 1.5 inches longer. plain design no logo black...then I placed a black sealer so no crap gets behind the guard.
working perfectly. also this is the same product that is on my 17 yr old truck.
these will not break very tough material stiff but flexible .
utkrstam
