Extending LED Light Wiring
Chilow
I had a set of Baja Designs led lights that I’ll be mounting to the rear of the vehicle. The included wiring doesn’t reach from the rear to the front of the vehicle where I need to hook it up to the battery. Is it possible to extend the wiring? If so, what is the safest way to do so? I don’t see any indication of what gauge wire is on the wiring from Baja Designs.
Figure out your amp draw and the total length of wiring, utilize any readily available wiring chart to figure out the appropriate gauge of wire. It should be noted that BD's wiring may not be sufficiently sized for longer runs (I've never seen their wiring, this is total speculation).
14ga wire should be enough for this case. You'll only need to run the power wire that whole way, just ground the lights near the mounting point. Use wire loom or something similar to fully protect the wire the whole way back.
Yes, I plan on grounding it to my Prinsu roof rack. I have some 14ga laying around so I’ll try that. Thanks for your help!
What model lights do you have?
We offer a 10' extension for the Squadron and S2 Series Lights:
https://www.bajadesigns.com/Products/S2-Squadron-Rear-Backup-Extension-10.asp
Baja Designs
www.bajadesigns.com
Any tips for extending the connections to the battery?
There are a few different methods of extending wires (crimping, soldering, quick connections, etc.)
We can't give a go-to recommendation since it comes down the personal preference. I will say, PLEASE keep the fuse close to the battery. If something shorts it will blow immediately and cut off the circuit.
Baja Designs
www.bajadesigns.com
Cpn2mss
