Factory Bushings
jca21
Anyone know if the 5th gen factory bushings are rubber or poly?
squeaking is starting to bug me and figured i'd lubricate them.
thanks in advance.
Not sure which bushing you are talking about specifically, but I am going to guess most likely rubber. Personally, I wouldn't go around lubing the heck out of all the bushings just yet, try to isolate the squeak first and then correct the exact problem. Most of the suspension bushings that did not come lubed from the factory don't need to be lubed up periodically either, so you might just end up masking the problem temporarily :)
peacefulpiranha
