Factory jack will not work for 2"+lift
JamesWhite
My 2010 4runner has 2.5" lift. I just realized it does not have enough height when I tried to use the factory jack (with a floor jack and jack stands) to rotate the tires in the weekend.
My solution is that a 4x4 wood block wiil be always in the truck.
Jack with 2.5" lift
It's a good thing you realized this before you had a flat. Maybe it's time to consider a taller jack or a high lift jack for off-road situations?
I once had an '85 Ford Ranger with a stock scissor jack that would not fit under the car when the tire was flat. I couldn't change a flat one day and had to buy another jack that collapsed lower. I bought a cylinder hydraulic jack. I still have that jack and take it 4 wheeling.
That plastic thing looks nice but I don't think it worths $55.
it is nice and works well.... they werent $55 when I bought mine.... but $55 is a small price to pay for a stable option if you don't want to 1. carry a hi lift and/or 2 don't have a strong enough jack point for the hi lift
Hmm.. Ive used the factory jack on my 2nd gen tacoma with 3" lift and 315/75r16s.. and it worked, but only if i positioned the jack under the lower control arm in front and the pumpkin/axle in the rear. I assume the same would go for a 4runner, just cant go off the frame.
Get a 2x8 and chop it up to 8x8x2 keep 3 or 4 in the back. Can be used for all kinds of stuff...
I like this better - wider - better balance.
Not to get off course, but I use stacks of 2x12 on all 4 tires to elevate an entire vehicle when I need better clearance to get underneath. Doesn't work for all situations, but quite a few that I need it to.
I know I'm resurrecting but it was never confirmed if this jack base would work with the stock jack.
So what is the verdict?
Asking bc the car wash place stole my block of pressure treated 6x6 :-(
The factory jack works with most lifts. You just need to position in properly. And that is not under the frame rail.
Hi-lift jacks should only be used as a last resort. The stock jack should work as long as you jack off the rear axle or lower control arms like someone mentioned earlier.
Have those additional multiple 4x4s for carjacks when you have to do other preventative maintenance. Lift the whole front or rear
