Factory Nav Unit for Sale
Ducseven
Factory Nav Unit SOLD......
I have a Toyota Factory Navigation Unit sitting on my shelf. Works with JBL Synthesis system in most Tundras.
It came out of a 2006 Toyota Tundra (was in mine)
Toyota Part #: 86120-0C160
Model #: E7006
I do have the Tundra Nav Manual and 2 CD's (one is a recent update) this is in like new condition, not a scratch.
The only part I don't have is the Satellite Receiver, (forgot to get it out)
They are for sale on Ebay for $50, just plugs in the back of the unit. Located here:
TOYOTA CAMRY TUNDRA NAVIGATION UNIT ANTENNA 06 07 08 09 : eBay Motors (item 330359483280 end time Mar-11-10 01:20:29 PST)
You can offer the guy less, I've seen them sell for $30
SOLD
I do not know what other vehicles this will fit, that's what I'm going to tell you when you ask. It's up to you to look up the part numbers.
If you want larger pictures let me know.
Thanks for looking
do you already have the JBL synthesis pre installed in your truck or does this come with the wiring and amp for non JBL equipped models? I really want the factory Nav back (I used to have it but sold it when I thought I was selling the truck, but decided to keep the truck)
This does not come with anything else, just the nav unit, manual and discs.
I did have the JBL system in my Truck so you are correct in that you will need to have the JBL system for it to work properly.
Thanks, thats what I figured, unfortunately buying the JBL part of the system seems more expensive than the Nav unit :(
Yes it will, it's out of an 06 (see original post), your factory harness is already set-up for it. It is just hidden behind the factory stereo.
I just plugged mine into the back and it was good to go.
you mentioned that the unit needs a satellite receiver to make it work.. which kind?.. was looking at ebay like you mentioned but found nothing about a $50 part.. really interested in getting this but just want to make sure there are no surprises involved..
This is the ad on Ebay:
That is the exact receiver needed for this unit. Make the guy an offer, I've seen them sell for $30
No suprises, use your stock harness, your stock mounting brackets, (I needed to file mine about 2mm, took 5 min) install and your ready to go.
Let me know, I have it for sale on Tundra Solutions as well and got a PM this morning from a member who supposedly wants it.
Thanks,
Rob
I thought that there was a navigation module that was also needed that is stored in the right rear bin. will this nav unit come with that module?
Have no idea what a "navigation module" is.
I had this unit in my truck personally and the only two things it came with was the unit you see above and the satellite receiver which plugs into the back. It plugged directly into my stock wiring harness and worked as soon as I turned it on. Nothing else needed.
goddesszilla
