Factory steering wheel control harness help
dusty619
I was about to hook up the pacs swi-rc steering wheel control module and discovered the previous owner cut the harness. I vaguely remember the wiring and harness coming in from the driver side into the head unit cavity when I did this before. Right now there is no wiring coming in from that side. Can anyone confirm where the wiring comes from or what it looks like? Wiring colors?
All I have now is a bunch of cut wires. Thanks.
I installed this one (https://amzn.com/B004HKBY8G) over the summer. I took out the original head unit so the wires were fresh. The wires did appear to be coming from the driver's side. Regarding the colors, I followed the guide (http://www.pac-audio.com/pacproductdata/swi-rc/1_instructions/swi-rc_instructions_062513.pdf) and matched the wires inside the dash with the wires on the unit.
I hope this helps.
see if you can the wirecolor off idatalink maestro, I know it was a 3 wire hook up at the plug.
Violet/White
A
07
Not Connected
Yellow/Black
A
08
Not Connected
White/Red
A
06
I figured it out
Steering wheel controls are part of the large 20 pin harness, not the one with the power wire.
seltzernator
