feeler Group Buy: Coyote Enterprises Automatic Tire Deflators
blackoutt
CLOSED/Cancelled
I would like to gauge interest on a group buy for Coyote Enterprises MADE IN THE USA automatic tire deflators. I've personally tested this design next to another leading brand and the difference in firmness of shutoff and repeatability is astounding. There are tons of knock offs out there that are difficult to set, leak, bleed too slowly, and don't shut off at the right pressure. This is not the case with Coyote Enterprises deflators. Through extensive testing they've been tuned to be very sensitive to shut off pressure and durability. Set them once, install on each stem, pull the pin, and when it shuts off, it's at the right pressure every time, reinstall caps and store the deflators in the glove box for the next adventure. My deflation time for 4x 33" tires from 45psi to 20psi was less than 5 minutes first cap off to last cap back on including double checking end pressures, this will vary based on pressures and tire size. Includes 4 deflators, adjustable from 4-56 psi, comes with carrying pouch too.
I've found them listed elsewhere between $65-90. Because this is a fairly inexpensive product the discounted price would end up being somewhere in the $55-$60 range per set, depending on qty sold. How many T4R members would be interested in a group buy for Coyote Enterprises automatic deflators? Reply to thread with number of sets interested or questions. Thanks!
Coyote has sweetened the pot with a give away of an easy setting tool per 20 sets of deflators sold. This tool is a shrader valve "T" with one end that threads onto your valve stem, then you attach the deflator to one side of the "T" and check pressure/add air to the other side of the "T" while you adjust the deflator to exactly desired pressure. We'll assign numbers when paid and raffle it off by random draw.
I'll leave this open testing waters for another week before we set price and start signing up!
