FEELER: Used '99 Headlights w/ defects. *CHEAP*
JWaldz
Moderator
OEM Glass Headlights from my '99. Normal light output
One has a hole a little smaller than a dime (pictured) from a rock and the other has a bad seal cus it leaks water sometimes. I also drilled a small hole (pictured) in the bottom for a drain when it does leak. Insides of them are a little dirty as well. RED MARKS IN PICS LABEL THE DEFECTS
I got tired of them leaking water and having to go through the warranty process for replacing my HID bulbs so I bought new headlights finally. They aren't in but should be at the end of next week.
Could be used for a trial and error pair if you're going with a projector retrofit and don't want to mess up your good pair. Or you could take them apart, clean them up, patch the holes, and they'd work fine.
Price is $25 shipped. I'll throw them away otherwise..
ALSO here is a link for a couple other lighting items I'm selling in an old post on TTORA >> CLICK
NVBASSJUNKIE
