Firewall grommet plug
arehman11
Does anyone know the part number for the firewall grommet plug? I decided to remove my grill lights and want to replace the gromet as mine has a hole cut in it. This is the one that sits a bit higher up on the driver side and doesn’t have any wires running through it.
can you even replace it without having to really mess with the stock wiring or do the wires have a connection nearby that's easy to undo?
I’m thinking he’s talking about the smaller one that’s near by the main harness. I personally would not be messing with that harness.
That would be the one, It sits a bit higher up from the one where the main harness is. Probably about the size of a penny or nickle at most?
I ran my grill lights to a switch in the cabin through that hole. For some reason, I found a rubber grommet with a hole in it from a prior project that was just the right size in my miscellaneous box of stuff. I used that to replace the stock plug, which I don't need anymore. DM me if you want it and I can send it your way (I'll probably have to find it in my miscellaneous box of stuff, but it should be near the top since I just did it.)
Thanks! That would be awesome. I'll send you a message
It’s this one. Just PM where you want it sent.
utkrstam
