Fix for Broken Key Fob Hole
TiN
Hey guys, got this idea from my dad when his keyring hole on his Sequoia key fob snapped. Threw together a prototype, and let it print overnight. As you can see, I opted for a simple piggyback clip design. Currently, I'm trying to get it as low-profile as possible. What do you guys think? Is there a need for this type of thing?
IMAG0122_zpsdcxg5q8j.jpg~original
IMAG0126_zps4qqtaq5o.jpg~original
IMAG0127_zpsos7riq2x.jpg~original
IMAG0128_zpsgyrglls4.jpg~original
Nope doesn't get caught any worse than the OEM.. The size difference took a little bit but it has a nice feel plus the added benefit that if you drop them it won't crack the case like I did on my Corolla's remote.
This happened to my dads, and I just ended up drilling a small hole in the lower corner or the case and ran a keyring through it. Works perfect and is free
Yeah, I've seen those somewhere.... Does the silicone get hung up in your pocket, or is it still easy to maneuver in and out?
They work fine and all but in my experience they are a friggin' dust magnet! But hey maybe I've just got linty pockets, lol.
AutoZone and O'Reillys sell empty remote cases for about $15.00. I think cases labeled Camry are a fit for the 4Runner. I opened and transferred the board from inside my old remote to the new one. I had to use a dremel to shave off a couple of millimeters on the inside bottom of the remote to make room for the board. It works great and can be done relatively quick if have one of the stores near you.
I would pay extra for a nice aluminum case.
its could also be half as big...
Viper makes some nice looking keyfobs, I always thought that if they made the perimeter out of aluminum it would be a very classy touch and aid in durability.
The lighter grey area being made from Aluminum.
I would like to see a member come up with a cost effective aluminum housing that you can just place the guts of the factory fob in.
Pretty inventive. What is that?
I could always design a case that I prototype with plastic on my printer, and then send off the design to Shapeways to have it produced in steel or something.... Don't know how cost effective that would be though, I've never used Shapeways to produce any of my parts.
I took a quick look at the inside of the remote before I started designing the above clip. How is the board mounted in the shell? It looks like it's kinda tucked in there pretty tight.
When that happened to mine I just went with one of these:
Lucky Line 49001 Key Fob Protector : Amazon.com : Automotive
The fit is not as tight as I'd like but I've been using it for about 6 months now and it seems to work fine. I generally carry my keys on a belt clip, not in my pocket (except in Summer when I'm wearing shorts), so pocket comfort is not a factor for me.
$6 at Amazon, I got mine at a local locksmith for about $9.00. Worth it, to protect the remote (it's the only one I have!)
