FJ Cruiser Suspension on 2003 4Runner 2WD
dc42nr86
Just picked up some 2011 FJ Cruiser 4WD Springs and Shocks and successfully installed it in a 2003 T4R 2WD. The front shocks are a little bit wide at the bottom to fit in the bracket and had to be grinded down a little bit. The top of the rear shock did not fit in all the way and had to be grounded a little bit as well.
How do you like the ride after the swap? The 2007-2009's are a direct swap, the 2010-2011 requires modification. Sounds like that modification was easy enough (I've not done that, not many here have).
