FJ Spring - years 2011-12
BurghRunner
From reading the FJ spring swap threads, I understand that 2010 FJ springs require some type of modification for 4th Gens. Does this hold true for the 2011 and 2012 FJ springs as well?
In addition, do the required mods make it impossible to return to stock springs or move up to OME springs?
Thanks!
Incorrect the springs are the same the shock from the 10-12 are different. Since your just using the springs doesn't matter what year springs you use. The 10-12 uses a wider shock mount to the lower Controle arm
BillM777
