FJ swap
hdhp65
I did the swap JF (From a 2011 TRD FJ) swap and I am quite happy with the results!
I have a question tho...
When installing the front strut assy. I had to clock the lower strut mount to line up with the mounting location in the LCA. When I did this the spring rotated and is now about 1" away from the stop on the lower spring perch on both sides. Should I be concerned?
HDHP
As long as it doesnt make contact, especially at full drop,your good. Usually at times, it's the UCA that gets closer and have to rotate.
Jhunt
