Flashing High Beams without Low Beams?
Offroader
I have H.ID. on low beams, and I would like to be able to flash the high beams without the low beams.
Has anyone done this?
If you pull back on your turn signal lever, the bright lights (high beams) should flash. At least that is what happens with my 4Runner......even though I do not have HID lamps.
P.S. I hope I understood your question properly. If I did not, I apologize - as my blood sugar level is very low right now.
:bash:
No..He's saying that he wants to be able to flash his high-beams WITHOUT his low beams coming on, as it is not good for the HIDs. Even if your headlights are off, the low beams come on when you flash the high-beams.
You'll need to look at the wiring diagram, but it can be done. Ought to be relatively simple once you trace the wires.
I'm still working on my HID retrofit project. My solution to High Beam problem is a pair of PIAA 520 driving light. Due to the design of my mounting bracket, I'm not 100% sure if I can still correctly aim my stock high beam. So, a pair of PIAA aux light with 135 watt bulb should do the job:)
