Flat black TE wheels!
adio3x
Finally got around to painting my TE wheels for my SR5! Did a low gloss black and finished it off with a flat clear. Didn't upgrade to the 275s, decided to wait til I get a the toytec ultimate lift and get 285s. This will do for now. :thumb3:
~DIY~
Supplies:
-2 Cans of low gloss Duplicolor Engine paint.
-1 can of Krylons flat general purpose clear coat.
-2 cans Duplicolor General purpose primer (just make sure it bonds with metal)
-320 grit sandpaper
-acetone
-safety gloves
-rag
-Respirator face mask (you don't need it, but I suggest you go buy one so you don't die lol, about $25 at walmart)
-Safety glasses
Step 1~ Easiest way to do it is have your tire off the wheels (bought mine on ebay so they were shipped w/o tires). But if you do have the tires on, you can always do the index card trick. Stick index cards inbetween the tire and rim and mask it off. Wear all necessary safety gear before doing work.
Step 2~Get some 320 grit sandpaper and sand every wheel down. Even the area for the lugs. Take your time and get every crevice.
Step 3~After done sanding, grab a rag and some acetone and wipe the wheels clean.
Step 4~Lightly spray a coat of the primer, covering the whole wheel. I did each wheel individually, instead all 4 at 1 time. But I waited about 15 mins inbetween coats. Do a second a coat. Then when thats done, you can do this if you want, I did the inner barrels too, same method.
Step 5~When thats all dry, make sure their aren't any runs or bubbles in the primer. If their are, then grab some sand paper and sand it down. Next is the actual paint, use the same method as above, but wait 30 mins inbetween coats.
Step 6~ Next is the clear, same method as the painting stage.
Step 7~ Repeat everything above for the center caps, its not tricky, just lay them out, sand them and spray them down.
Step 8~ Let these dry for more than 1 day, I was too excited to put them on and mounted them the next day and now the paints peeling a little on the edge.
Sloanblack.jpg~original
sloanblack2.jpg~original
DSC_8815.jpg~original
wow, you sure know to wax...... the wheels look great.
Please let us know if you had any problems painting the cap. I hear they are a little tricky
Thought these were butt ugly before, but now you want me wanting this style to paint black for my next wheels!
Dude, you should know by now that you are required to post details and a write up if you are to be taken seriously on T4R.org.
Seriously, paint, method, time, coats, sanding, tire removal?
There are so many details missing it's criminal.
The end result is nice; they would be great paired with a Gray Metallic T4R.
I wasn't meaning to make this a DIY thread, I was just showing off my wheels lol. But in that case, I'll do a ninja edit.
Thanks for the writeup!
I think they look awesome. Any chance for a closeup photo of one of the wheels?
I've always wondered how durable Duplicolor home-painted wheels are. I've seen auto shows suggest that it is an inexpensive way to spruce up your wheels. But if they flake off when you clip a curb or whenever you get new tires installed, it seems like a real PITA.
I really want to paint mine either graphite or bronze. But... mine already have tires on them and they have balancing weights stuck on them. This makes it a PITA.
:iagree: Amazing how a little paint can make a world of a difference for those wheels.
Looks awesome adio3x.
End result looks great. You could have done this with less work. Unless repairing scratches or sand-blasting, primer is not necessary. A grey scuff pad and some blend prep, like PPG DX 101 and water would have prepared and cleaned the surface (without solvent) leaving it ready to paint.
Cool. Let us know how they hold up. Everyone seems to be deterred from painting it because they are afraid of scratches and scuffs...
Hey Andrew I'm not sure if you still have these rims or not, but how did they hold up in the long run? I was looking at getting my 20" Limited rims powdercoated, but this is obviously a much cheaper route. But my concern is durability. Any thoughts? :hungry:
They held up great, sold them over the winter to a guy with a tacoma. But overall they held up way better than I had thought on and offroad.
Ha, that's the same dude that bought my stock tires the other week. He found my posting on craigslist.
He was a nice guy, pointed out those black trail rims to me....looked good.
