Fog Light Assembly
Nashvillerunner
I am trying to install new fog light assemblies for my 4runner. I have disconnected the fog light bulbs and the front cover over the fog lights but I am unsure what my next step is. Does anyone have a link or video I can watch to install the new assembly?
Does this help?
Going to be replacing the fog light assemblies on our 2006 T4R Sport, does anyone know if you really need to remove the front bumper in order to do this?? Thanks
I just replaced my broken fog light assembly on the passenger side of my 2006 Limited T4R and it wasn't bad, but took me some time since I had nothing to go on.
All you have to do is remove the trim piece in front of the fog light assembly, remove the splash guard trim under the wheel well so you have easier access to the fog light. Remove the bulb from the housing. There is a plastic piece with tabs attached to the adjustment screw on the back of the fog light that holds the assembly in place, so you have to squeeze the tabs inward in order to back it out of the hole.
The last thing to do is just get a good grip on the assembly and pull from side to side until the side tubular pieces pop out of the holes in the bumper and then pushing away from the bumper the fog light assembly will pull out from the front end.
Just do everything in reverse.
Now that I have done it and know what to expect it shouldn't take me so long to do the other fog light assembly when it breaks. :rockon:
I hope this was helpful, sorry I didn't have any pictures but it was a pain trying to do this and had to use both hands.
I replaced my fog lights with Baja Designs Squadron Pros. I did a little write-up on it in my build thread, here's a link in case it helps: LINK
Thank you. That helps alot. Hopefully it goes smooth next week when the replacements get here. Swapping out both headlights and fog lights, they all had bad moisture inside when I bought the T4R.
