Foglight Bulbs - 05
From the backside they should just latch in with about 1/4 of a turn then slide right out, same as the headlight bulbs.
Man, my weren't going to come out.. I stopped trying to twist them out as I was sure the whole unit was going to snap off.... that's why I figure there was some kind of latch or screw holding them in...
Do you need to remove the rubber cover first?
Are you sure that you are turning them the correct way? I had this problem also until I realized that I was turning them in to the wrong direction. If you are laying down under your lights and you look up, I believe the one on your left side needs to be turned to the righ and the one on your right need to be turned to the left. Mine were a little difficult to get out but I eventually did. See if that works for you.
averyberryman061493
