foglight mod for 2014+???
We obviously need more information before anyone can help you.....
Auxiliary fog lights, Dual function LED fog lights with DRL, Morimoto direct replacement LED fog lights, just putting another ole' bulb in your fog light housing, putting LED's in your fog lights?????
See there are numerous ways and numerous answers!
:pop2:
Installed mine last night
:pop2:
As in running fog lighs when parking lights are turned on not just when headlights are on
I also have one here, just more of an extension of Antman's. Because yours is newer, you'll need to double-check the wiring to make sure its the same as the older 5th gens wiring.
Super easy if you don't mind not having the green foglight led in the dash when the lights are turned on.
Honestly i was just gunna get a h11 wire harness and tap the power to the tail lamps and get a aftermarket push foglamp switch with it, seems like it would work, but if i could find a way to use the factory switch and without having to get another harness that would even be better, i guess ill oneday open up my dash and check if the wiring is the same as the earlier model 5th gens
If you're good with wiring, then all you need is a relay and some wire, here's my diagram for wiring it in:
If you wanna go the extra step and getting the fog led in the dash to work, you'll need a 12v green led too. This will allow you to have it wired to parking lights for power, and if you don't wanna screw with the stock switch, then just add an SPST switch in the dash somewhere!
Make sure to take pics and notes for the newer guys if its not the same!!!
Mike Sargent
