For Sale - Vision-X Xmitter Prime Xtreme 18" LED Light Bar
SOcalTRAIL
5-Watt LED emitters!
14,790 Lumens!!!
18" Light Bar with Custom Optic Configuration - 40 Degree Optics on the outer ends, 10 degree optics on the inside.
Ordered directly from Vision-X, it was removed from the packaging to check for fitment on my truck, lit it up for about 30 seconds to make sure it worked, and returned to the packaging. Literally like new. Cannot be returned due to the special order custom optic configuration.
http://visionxsuperstore.com/18XmitterPrimeXtremeLEDLightBar5-WattLEDs.aspx
Asking $750+shipping.
Comes with all the original hardware.
Pics:
file_zps9f281bab.jpg~original
file_zpsc5f161a9.jpg~original
file_zps83584989.jpg~original
Here is the description and specs from Vision-X:
The Vision X 18” square XIL-PX2.3010 features Prime Drive Technology, a narrow beam pattern that offers you great distance with little spread to the beam, and black aluminum housing. The XIL-PX2.3010 comes standard with an extended warranty, and multi-volt 9-32V DC input. This light weighs 9.25 pounds and offers a mounting depth of 2”. Coming with Prime Drive for enhanced reliability & output and our new 5watt LED’s this light has an extraordinary light output. Overall length is 17.5", power draw is 150 Watts.
Why Xmitter Prime XP
The Xmitter Prime XP Bar achieves the farthest lighting distance and brightest output in the Vision X Light Bar lineup. This is due to the 5-watt LEDs that are placed much closer together on the circuit board than 10-watt LEDs allowing for greater optical control and therefore greatest distance. The Xmitter Prime also makes use of Prime Drive Technology which manages heat levels to prolong the life of the LEDs.
Key Features
>Integrated Electronic Thermal Management (ETM)
>New Generation LED is Driven to 90% Efficiency
>Defined Optics Optimize Distance and Depth
>Advanced Heat Sink Designed to prolong the life of the LEDs
Prime Drive - The Smart LED Bar
ETM monitors the heat output of the LEDs and makes use of integrated Pulse Width Modulator dimming circuitry in order to maintain safe operating temperatures in order to prolong the LED life span to its full 50,000 hour potential.
Pulse Width Modulator Dimming
The Xmitter Prime XP utilizes integrated Pulse Width Modulation (PWM) dimming circuitry to manage heat levels. PWM works by flashing the LED at a frequency faster than the human eye can detect, reducing the time that the LED is operating while still delivering 100% light output.
Bold, Strong Design- The Tough LED Bar
Extruded 6061 Aluminum
The Xmitter Prime XP is housed in 6061 extruded aluminum for ultimate strength and durability.
IP-68 Rated
The Xmitter Prime XP has achieved an ingress protection rating of IP-68, signifying that it is dust-proof and submersible in water up to 3 meters.
Proven Mounting System
The Xmitter Prime XP utilizes the Vision X signature stud mounting system that allows for 15° of adjustability and helps to control vibration through the use of isolated rubber in the mount.
limeaura
