Fox Fabtech Coilovers
Buy Fabtech Coils
  • Total voters
    12
97Run-Man
Need Advice guys. I found these Fox Fabtech coils for a good deal ($300 shipped fresh rebuild) and am wondering if I should get them or not. I have seen so many differnet view points on them. I need a new set up, up in the front but I don't want to waste money. If this is an honest to God good deal I could use the saving for the rear but if not I'll put up the money for something good this time.
Thanks a lot guys.
If they're Fox's they should be good, and that seems like a good deal. Since they say Fabtech that's throwing me off though since I'm only familiar with them doing drop brackets, which would make me think they're coilovers meant for a huge lift which wouldn't work with a stock geometry setup.
[MENTION=87781]97Run-Man[/MENTION] Compared to the factory struts and coils they're fantastic, but compared to an Icon 2.5 remote resi with CDC valves they're junk. It depends on what you're going to do with them. If you're looking at hardcore higher speed wheeling while carrying a bunch of gear then they will probably not be the best choice. If you're doing mild off-roading they'll do fine. Regardless they're much better than the stock setup. I ran them for 10+ years in my Tacoma, and the only time I had issues were when I was driving fast on bumpy desert trails as the shocks would start to fade and needed to cool off.
I have Bilstien shocks and ebaich coils. I really am not impressed with the ride quality or anything. They are far harsher then stock and do not give at all even with a new plate steel bumper. I want to get a nicer ride that will perform better and not be so rough. I just need to know I am not gonna make this mistake twice.
Then I think they will fit the bill just fine. I had them with an ARB and I thought the ride was great. If they're stiff you can always crank them down but you'll loose some lift. If they're still too stiff you should be able to get different springs for those coilovers too.
[MENTION=87781]97Run-Man[/MENTION]Did you end up buying these? Are they any good?
Also what 5100's did you have tacoma or tundra?
No I didn't not get these. I went with radflow 2.5" coils and 650 lb springs.
I believe they were tundras. All I really remember is they had 5 adjustable perches not just 3.
Does anyone have experience with these, I am in the same dilemma and trying to figure out if these coilovers are any good? There is little to no info online about them because these came out so long ago
Get them! I picked up the same the exact same set a couple months ago for about $200. They need to be rebuilt, and that costs about $200 as well.
As far as rebuilding goes I have found that Mirage racing rebuilds them:
Mirage Racing Products Fox Fabtech Shock Rebuild
But I contacted FOX and they said they will also rebuild them, the guy I spoke with sounded super stoned over the phone and wasn't able to provide me with any actual information but the vague numbers he threw out made it seem like it might be cheaper to just have fox rebuild them.
As far as I understand the rebuild process is quite simple and can be done easily at home with some basic tools.
Can you recommend a spanner wrench to use on these? the pair I bought came without the wrench.
Thanks.
Where can they be purchased from?
I found them on craigslist or the forms classified section. Can't remember. It was a good deal, but from the info I found they weren't worth it. I had to much weight in the front and was only going to be adding more. Made sense to go with a better product instead of having to change again.
I recently picked up a set and they also need to be rebuilt, I have been looking around trying to find out if they are worth rebuilding. So far I have not found anyone currently using these who can comment on how they perform.
Thanks.
Mirage is who I planned on using for the rebuild. I think it'll end up costing about $350 by time it's all said and done with shipping.
I bought mine from a member on here who swapped out to Kings. He used them for a long time, and had nothing bad to say about them. Guess we'll find out though. This is the wrench that I bought.
I picked up a used set and just recently rebuilt them myself. Way better than my stock suspension that had 180k. I paid 150 for them used and put 80 bucks into rebuilding them(lower bushings, seals, oil) myself. I had never rebuilt suspension before so it was a learning process. But was really rewarding doing it myself. Now I just need to install my 8 wraps this weekend.
[MENTION=120189]dmag310[/MENTION] so you're going to run these and 8 wraps? Thats what I've got sitting in my garage. I'm curious what it'll look like complete! :) Where did you find a rebuild kit if I may ask?
Ive been running mine for too weeks, major improvement over stock. Im running OME 890's in the rear. I wish i had gone with the 8 wraps instead...
Can you give some more details on this? I'd love to rebuild them myself, and save some.
PRWhite
