FOX Shocks - Off-Road 2.0 and 2.5 Options
Wanted to share a 2.5" Update - Factory Series
2010-2019 2.5 Coilovers and Shocks (Factory Series)
880-02-361, Front, 0-2" - Limited Stock
883-02-025, Front, 0-3" - Backorder, ETA End of September
883-02-111, Front w/Res, 0-2" - Limited Stock
883-02-130, Front w/Res, 0-3" - Backorder, ETA End of September
883-06-111, Front, w/Res, w/Adj, 0-2" - Limited Stock
883-06-130, Front, w/Res, w/Adj, 0-3" - Limited Stock
883-24-004, Rear, 0-1.5" - Limited Stock
883-26-004, Rear, w/Res, w/Adj, 0-1.5" - Backorder, ETA end of September
FOX Shocks - Click Here
_
Here is a quick update on FOX 2.0, Performance Series...
Front:
Part #983-02-051 - Available
Rear:
Part #985-24-124 - Available
Part #980-24-679 - Available
Part #985-24-117 - Available
Part #985-24-118 - Available
Part #985-26-117 - Limited Stock
Part #985-26-118 - Available
_
Here is a quick update on FOX 2.5, Factory Series...
Front:
Part #880-02-361 - Limited Stock
Part #883-02-025 - Available
Part #883-02-111 - Out of Stock
Part #883-02-130 - Limited Stock
Part #883-06-111 - Limited Stock
Part #883-06-130 - Available
Rear:
Part #883-24-004 - Limited Stock
Part #883-26-004 - Available
_
FOX 2.0 and 2.5 Coilovers and Shocks fills a lot of build options.
Standard Travel 2.0 Coilovers for 0-2" Lift and 2.0 Shocks for 0-1.5" and 2-3" Rear Lift Options
Standard and Extended Travel 2.5 Coilovers for 0-3" Lift and 2.5 Shocks for 0-1.5" Rear Lift
_
why no front 3” lift?
Sent from my iPhone using Tapatalk Pro
FOX is a great option for many 4Runner Enthusiasts, as they offer both a 2.0 and 2.5 Front and Rear.
FOX 2.0 Strut and 2.0 Coilover are both Standard Travel, 0-2" lift.
FOX 2.0 Rears shocks have several options in both 0-1.5" and 2-3" lift.
FOX 2.5 Coilovers come in both Standard Travel (0-2") and Extended Travel (0-3")
Extended Travel Coilovers do Require Aftermarket Upper Control Arms.
FOX 2.5 Rear Shocks are limited to 0-1.5"
FYI...
FOX Performance Series are the 2.0 options
FOX Factory Series are the 2.5 options
_
_
Looking for FOX 2.0 and 2.5 Coilovers and Shocks?
Click Here
Please feel free to contact us or PM us for availability.
Remember when ordering online to use Promo Code "T4R" for added savings on most brands.
_
I have a question pertaining to the Fox 2.5 Rears for a 2014. They are labelled as 1-1.5in of lift. If I wanted to add a spring that adds 2-2.5in of lift how would this affect the Fox 2.5 rear shocks?
Would they over extend and ruin the seal?
Thanks, just curious since most people want the bigger volume of the 2.5 but the limiting height is something to note.
FOX 2.5 Rear Shocks are good for 0-1.5" of lift.
The FOX Rear 2.5 Shock is not a good choice for 2-2.5" Rear Coil. Going with a 2-3" rear coil will result in premature failure over time.
A better FOX option would be to pair Front 2.5 Coilovers with the Rear 2-3" 2.0 Shock, Part #985-24-118.
_
Kaliram
