Frame Rot!! Is this the end?
TheDurk
Elite Member
Durk's 3rd Gen 4Runner DIY Frame swap and more
tXWWp1eUbf4q5YE8XtSO8dlam94yfUYTt2b-RCOFgF7-Lh2lqMvXb_bh5DAACviBujzEVsrzk2QlrA=w2880-h1620-rw-no
This is where my rear control arm bracket is supposed to be. This rust out was totally stealth; from the outside it didn't look that bad. It rusted from the inside out and I didn't know I had a problem until the control arm fell off.
I took it to two local welders and they didn't want to touch it. I don't think this frame can be saved. The other side is almost as bad. There is no metal on top of the bracket there either. A screw driver punches right through.
I can part it out and start over and get myself a whole different truck.
But I'm leaning towards doing a back yard frame swap with a used frame from a junkyard. I have a backup car so I can take my time. Has anyone done it?
Find another fab shop, keep looking, seen way worse fixed before. Maybe an Offroad shop
Sent from my SM-G900P using Tapatalk
Don't see the pic! Whish my friend wasn't selling his house he has a garage with lift and every tool you can imagine. I'd ask him to weld new metal for you. But he's losing the garage :(
Ouch. I am no frame expert, so put little weight in my opinion... I would definitely say THAT frame has had it! Especially since you said that it was looking ok from the outside but then rusted out from the inside... I think there is no telling where the next hole will spring up. I would have no confidence driving on that frame, even after the visible spots are fixed up really well.
I think it all depends on how much work you want to do. The reason a welding shop doesn't want to mess with it is due to the work involved. That's a pretty big section, but it's repairable. The only thing I'd be concerned about is how the rest of the frame it. If the rest of the frame is good I'd fix it.
I bet you'd save money by doing it yourself. Even if you have to buy the welder. If you need pointers let me know since I've already repaired mine, and I have more to do this fall.
I repaired worse, on old Jeeps. But the end result didn't look like an original frame. And after spending 3 days cutting grinding and welding. We took it on a trail and the steering box fell off, with a big chunk of frame. Fixed that too, but my friend sold it after that.
I've done a few frame swaps, always on Chevy trucks/suv type. The first one I did was an 87! That was awful because they didn't build things the way they do today, so pesky things like wiring harness were a major hassle. Today you can disconnect from the firewall and be done. The ability to lift the body is all the difference in the world. A two post lift makes it a cakewalk, doing it with jacks and slings and your brother in law's high lift is just stupid.
I say go for it anyway, but if you sell and replace, don't change your avatar.
:plane:
if you can find a frame to swap, i would blast and re-coat everything you can and then try to coat the inside with fluid film or something similar before swapping.
I've had to weld a couple sections on my frame. A buddy of mine with a beautiful sport had the bracket bust off the frame. A shop welded new C-channel over the frame and remounted the bracket to the new metal. People think that welding on the frame is the worst thing ever. It can be done with a 110 welder, grinder, wire brush and some clean steel and hold up for years.
As long as the shop is trusted and takes their time, or if you do it yourself, I think it can be fixed.
Well, I don't weld, but I do wrench. I just got back from my local junker and he has a 2002 with a decent frame--solid in all the places mine is dust and just surface rust in spots. It was was junked in 2012 so it has only ten years on the road. It wasn't a collision--the body is intact, but nobody knows exactly why it was junked. Fine with me. Got it for $500 plus $100 delivery. Arriving by the end of day.
I spent a late night researching this and I believe I can do this in my yard with jackstands and an engine crane, all of which I have--I think. One guy has a vid of how he did a Taco. I love this truck too much to do anything less.
POR15 plus prep stuff and Eastwood Internal Frame Coat is on the way. Going to do LBJs, UBJs, both TREs, fuel pump, muffler and tailpipe at the same time. Shocks and springs are relatively new. Cats still look solid. Only the front '99 talls are original, but they seem fine with the new Trekmasters on them. Maybe bedliner the underbody while the frame is out. I'll have a new truck under there when I'm done.
I have the time and a backup car--POS '08 Hyundai Accent that is family reserve car, but it runs. So watch this space for a Backyard 3rd Gen 4Runner DIY Frame Swap thread. May take a while but I'll have my truck back. She's been a faithful DD, moving truck and adventure ride since 1999 and she deserves it.
there was a guy over at YT who did a frame swap with the donor frame coming from another YT member who had either a 2002 or 2001, can't remember exactly.
Frame rot aside, I think this is the first question I've ever seen [MENTION=10169]TheDurk[/MENTION] ask in my few years as a member here.
Yes please document this ( but seriously why can't I see the pic of your frame ?) if you do frame swap. Wire wheel the whole frame. Get por15 metal prep and marine cleaner. And lay the por15. Then like monstaliner it. Eastwood internal frame costing inside.
If you've read this forum since 2006 almost every day, you really have little need to ask questions. What I haven't already learned, I know where to find.
Exactly my plan.
Sorry to hear about your frame. It's a battle with the salt where we live & the box frame holds dirt & moisture. If you need help let me know..but lets wait until Sept because this heat efn sucks!!!: I more than anyone knows the emotional attachment to the 99. :cry:
I'd be scared to buy a junked truck from up here. These trucks rot out just from being parked on gravel, dirt & grass. Luckily I parked on cement in LI & Blacktop here in Monroe. I'd probably look to the Southwest for a truck or frame if it happens to me.
Sorry to see this Durk, but you're acting quick. You already bought a new frame before I could suggest that.
Even just come down here to the southeast. My truck has never seen salt and the undercarriage is just about spotless. Only very slight surface rust where the paint has been chipped off.
I don't mess with rust, I cringe when I see cars from up north.
