THatfield
Please read this ad carefully before you get giddy about a free set of fogs.
2 of these 3 fog lights are operational. HOWEVER, 2 of them need to swap parts to resurrect the other into a working unit. One unit, the bulb burnt out and the screws holding on the access port to replace the bulb are frozen with rust and are in danger of being stripped. The other fog light is riddled with corrosion inside. Piece these two together and make one good fog light to match the other working one. They are a set, driver and passenger. I believe the spare is passenger as well, which is convenient given that the two passengers are the ones you will need to perform surgery on. I also have one bracket, and I believe it is for the drivers side but am not sure. It has a broken bolt that will need to be removed in order for the fog light "pod" to fit securely.
Just pay shipping and they are yours. If you really want pictures PM me, but they are the projector style 99+.
Shipping from 43068 to your location is on your dime, or I can meet locally in Columbus.
